Bolt size for AIR plugs
I am in the process of doing a heads and cam swap and was planning on removing the AIR sys. in my car. I have AS&M headers and am going to need to block off the AIR ports. What size bolts do I need to plug the header holes? All i can seem to find is that it might be a M22 oil pan drain plug. If that is it where can you get them? I've done a search and have not found any sure answers for my question. Thanks for your help!
Hey, thanks!
I thought that it was an M22 but wasn't sure. I tried all of the local parts stores today and the bigest anyone had was a M20
The dealership had one but they wanted $15 and some change for one of them! I guess I'll have to do some more searching. Thanks again.
I put a washer under the drain plug.
http://www.97ta.com/lt4/lt495.jpg
Originally posted by TUFF LT1
Did any of you use any kind of sealant along with the M22's or do you not need to???
i had no problems with them leaking.
jesse
I had already taken a look at your pic on another thread and was planning on doing the same thing on mine. Thanks for the pic
Hey Jesse thanks for your reply on both of my threads. I was just wondering because the directions for the ARP bolts that I bought say to torque to 85 ft. lbs. if no sealant is used and 65 ft lbs if ARP sealant is used. Is their sealant any better than the stuff at the autoparts store???
