Part Numbers and other things.
Old Jan 4, 2004 | 12:41 AM
Austin96Formula's Avatar
Ok, i'm gonna be fixing the oil leak up front on my car sometime soon, and should I stick with GM parts of get FelPro stuff? I know I need to replace my oil pan gasket. I might also do a cam swap and heads at the same time. But more then likely it's just gonna be fixing the oil leak. I think I found the p/n for the FelPro stuff TC545966 is the timing cover and related parts (minus the crank seal) and OS34500R is the oil pan gasket. Maybe I should just live with that leak untill I can replace the heads.
Old Jan 4, 2004 | 09:01 AM
The Fel-Pro gaskets should be fine.
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
