On stock heads are some intake runners smaller than others?
Old Jan 3, 2004 | 01:28 AM
LT1RX7's Avatar
I'm porting heads for the first time and when I scribed them for gasket matching I noticed that the outer runners are way smaller than the middle ones.
Does that mean different runners have different flows in stock form?
Old Jan 3, 2004 | 02:14 AM
97WS6SCharged's Avatar
If you measure the flows of all the runners on a flow bench, they should be pretty close to each other, but they won't be the same. As far as the outer runners being physically smaller, it's most likely an attempt to keep the velocity high.
Old Jan 3, 2004 | 02:55 AM
LT1RX7's Avatar
so when gasket matching the runners do I want to actually match the gaskets if in stock form they are very close as far as flow goes? If I port more on one runner than I do others won't I get different flows?
Old Jan 3, 2004 | 03:24 AM
As long as you're only gasket matching you should be ok. Just be careful if you go deeper into the runner.
Old Jan 3, 2004 | 09:30 AM
OldSStroker's Avatar
Don't gasket match. It just gives you a bigger area in the middle of the total intake tract (from manifold plenum to valve). That doesn't help flow, it just slows it down then speeds it up again as the cross sectional area changes. Each change in velocity uses up energy.
Yes, probably. DIY porting without a flowbench and some knowledge is about as effective as DIY surgery. Sometimes it works, and sometimes it just hurts.
Old Jan 4, 2004 | 06:03 PM
arnie's Avatar
To give you a pic, as an extention of what OldSStroker is referring to, scrol down aways, and check the pic, in link below, displaying the intake assembled to the heads. Ya, it's an LT4. but the intention is to show the relationship of head port to intake tract. To that end, it is extemely similar. The intent is to put in a visual sense, the intake is an extention of the intake port in the head. What the porter is striving to accomplish, is to have a uniform cross section area, in any given section of the port.
http://pws.chartermi.net/~steveher37/LT4/lt4.html
Edit: BTW, B4 anyone scrutinizes the LT4 manifold port to head port alignment, and attempts to make an issue, the pic referred to above, is (I firmly believe) an LT4 engineer's rendition of how the LT4 manifold port was intended to align, in respect to the opening/port in the head. It is not, what we, the consumer ended up purchasing. A 'bean counter' took care of that.
HectorM52
Jul 30, 2017 11:46 AM
Jason Short
Jan 19, 2015 06:34 PM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
Killer94z
Jan 13, 2015 12:06 PM
birdblack
Dec 30, 2014 06:59 PM
