On stock heads are some intake runners smaller than others?
I'm porting heads for the first time and when I scribed them for gasket matching I noticed that the outer runners are way smaller than the middle ones.
Does that mean different runners have different flows in stock form?
If you measure the flows of all the runners on a flow bench, they should be pretty close to each other, but they won't be the same. As far as the outer runners being physically smaller, it's most likely an attempt to keep the velocity high.
so when gasket matching the runners do I want to actually match the gaskets if in stock form they are very close as far as flow goes? If I port more on one runner than I do others won't I get different flows?
Don't gasket match. It just gives you a bigger area in the middle of the total intake tract (from manifold plenum to valve). That doesn't help flow, it just slows it down then speeds it up again as the cross sectional area changes. Each change in velocity uses up energy.
Yes, probably. DIY porting without a flowbench and some knowledge is about as effective as DIY surgery. Sometimes it works, and sometimes it just hurts.
http://pws.chartermi.net/~steveher37/LT4/lt4.html
Edit: BTW, B4 anyone scrutinizes the LT4 manifold port to head port alignment, and attempts to make an issue, the pic referred to above, is (I firmly believe) an LT4 engineer's rendition of how the LT4 manifold port was intended to align, in respect to the opening/port in the head. It is not, what we, the consumer ended up purchasing. A 'bean counter' took care of that.
