Sway bar upgrade from 32/21 ----> 35/25 worth it for AutoX?
Did a search and didnt find exactly what I'm looking for...
I have the 32/21mm sway bar setup now and am racing in ESP.
Has anyone upgraded from this to the Suspension Techniques 35/25mm setup?
Was it worth it?
Was it worth it?
Re: Sway bar upgrade from 32/21 ----> 35/25 worth it for AutoX?
Was it worth it?
Was it worth it?
However, I do run the 35mm front, and I swear by it. Camber control, response and wheelspin are all helped by the bigger bar. But again, it's a matter of what other parts complete the package. Don't try and use a bar if it's really better dampers. Or trying to use a really big bar with odd spring rates, etc.
Thanks for the reply Sam....
I think I'll be ordering that ST 35mm bar from you pretty soon.
Unrelated questions about shocks for you....
In lurking around your website, I noticed you sell Revalved Bilsteins, and that you said the regular Bilstein HD's are not what you would recommend....
Whats the difference between your Revalved Bilsteins and the regular HD's that I have? Just more agressive or what?
Also, why dont you recommend the HD's for handling?
Thanks again
Thanks again
Revalves are different in rebound damping rates and can be different in the way the damping curve is shaped depending on the goals. And they are not NOT a standard valving. Not everyone gets the same things. It's done on a case by case basis for each customer
I'm the "big" bar kind of guy. 35mm front is one of the best investments you can make. I use a 21.5mm LG Motorsports rear and like it, seems about perfect for my style of driving. BUT, listen to Sam's advice.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
carguyshu
Jan 22, 2017 11:19 AM
96SilverRam
Nov 20, 2016 11:19 AM
