Autocross and Road Racing Technique There is more to life than a straight line
LG Swaybar too close to 12-bolt pumpkin
Old Oct 27, 2003 | 02:46 PM
zhevy-1's Avatar
I just put a Moser 12-bolt on my 96 Z28 and the swaybar is touching the bottom of the 12-bolt pumpkin.
Do I need to add washers to the U-joint that ties the swaybars bushing in place?
Thx-Goose
Old Oct 28, 2003 | 11:50 AM
Z28SORR's Avatar
I know this is obvious, but is the weight on the wheels?
Old Oct 29, 2003 | 08:54 AM
zhevy-1's Avatar
I have the car suspended on a lift. The wheels are not touching anything. I will see how it sits on the ground. There's just barely some clearance between the swaybar and the bottom of the pumpkin. I may be fine, once it sits on the floor. we'll see.
Old Oct 29, 2003 | 02:56 PM
coletrickle350's Avatar
I hade the same problem with a strange 12.
my sway bar was hitting the diff cover on the bottom of it.
I simply ground down the diff cover a bit and everything clears nicely now.
Good luck Mike
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Sep 17, 2015 11:53 AM
Toxintwins
Sep 11, 2015 11:13 AM
