Autocross and Road Racing Technique There is more to life than a straight line
use my stock WS6 springs in the rear or the pro kit springs
Old Oct 25, 2003 | 09:36 PM
TA Dreaming's Avatar
so i did the novice school today and had a blast, but its been decided that im sitting lower in the rear than the front and ive decided im still bottoming out too easily. i have the pro kit on my car now with bilstein HDs all the way around. the back end bottoms hard and too easy for my tastes. the shocks made a big improvement compared to the de carbons that were on there, but it still happens.
so what im curious about is will going back to my stcok springs which should be 1LE springs be a step in the right direction? yes it will raise it up(hopefully enough to stop bottoming out) but the 1LE springs have a lower spring rate than the pro kit even though its the progressive version of the pro kit. i would rather try dealing with the bottoming issue and not change the springs than to change the springs and then have a back end thats too soft. so whats yalls opinions? thanks Trey
Dec 1, 2014 08:08 AM
Z28STYLE23
Aug 17, 2002 07:40 PM
MJ_Z28
Aug 8, 2002 09:07 PM
MJ_Z28
Aug 7, 2002 07:15 PM
Z28STYLE23
Aug 4, 2002 03:30 AM
