LT1 won't rev??
LT1 won't rev??
I am helping a friend work on his '96 (LT1, OBD2). It has a new 383 with a Procharger D1. Runs fine up to ~3,800rpm, then starts to run very rough. Occurs under load or in neutral. Here's some info.
No codes except "High MAF".
Good AF ratio.
Replaced Opti.
Put in known good MAF.
TPS checks out fine.
New plugs and wires.
Intake is not collapsing.
Replaced MSD box.
Fuel pressure is fine.
Anyone have any ideas? I don't have a clue.
Rich Krause
Good AF ratio.
Replaced Opti.
Replaced MSD box.
Rich Krause
Originally posted by madwolf
Does he have cats still? How about timing, are you sure it isn't too much? (in case he doesn't have tuning/boost retard box)
Rich Krause
Oh yes, if they're clogged, they will definetely cause something like that and gradually get worse.
I don't know how the air fitting are on an OBDII car, but you could try unbolting the pipes from the manifolds and run the car like that. It will be loud, but if the problem goes away, the cats are bad.
Anyone else?
Rich Krause
Mechanical timing
If the motor is fresh and the cam has just been either installed or reinstalled then I might suggest checking that the cam timing is correct. If its off by much that could be the problem. Either or degreeing and or off one tooth could do it. Good luck.
Vince
Vince
If he still has cats on his car (they need to be off anyway
) I would bet 99% that is your problem. My buddies cat clogged on his low mileage '94 Z28 (34,000 miles) and his car would rev up to redline, but would take forever to get there. The only other suggestion I would say is fuel pump not keeping up with demand, but you said you already checked fuel pressure. Good luck!
Jeff
) I would bet 99% that is your problem. My buddies cat clogged on his low mileage '94 Z28 (34,000 miles) and his car would rev up to redline, but would take forever to get there. The only other suggestion I would say is fuel pump not keeping up with demand, but you said you already checked fuel pressure. Good luck!Jeff
Originally posted by Seal
cats could be it, but it wont make that much of a diffi think...
are you making any mechanically weird noises? have u atapped it to see whats going on when it gets rough?
Just some ideas: Valve float, collapsed lifters, worn valve springs?
We had a dyno day recently with our local club and a guy there had similar problems ~4000 rpms. Car ran fine before that but after was real rough. The general consensus was he had valve float, or possibly a collapsed lifter due to high milage on his heads. I know you said it was a new 383 motor, but what about his valvetrain?
Rich Krause
