SES light
Old Oct 7, 2003 | 02:11 PM
ead94z28's Avatar
Question SES light
I had my coolant flushed today and shortly after my ses light went on. I noticed that the cooling fans went on abnormally early, like around 180*, and at the same time my ses light went on. Any ideas what this could be caused by?
Old Oct 7, 2003 | 02:15 PM
Only way to be positive would be to check the codes with a scanner. Is it possible they knocked the connector on the coolant temp sensor off? It's on the front of the water pump. Or, did they get sloppy with the coolant, and perhaps drench the Opti, or the AIR pump?
Old Oct 7, 2003 | 02:23 PM
ead94z28's Avatar
Coolant temp sensor is still connected and everything is dry as a bone down there.
Old Oct 7, 2003 | 02:25 PM
Check the fuse for the AIR pump. That is a common problem, and turns on both fans. Could be just coincidence it all happened at once.
Old Oct 7, 2003 | 02:29 PM
ead94z28's Avatar
I'll check it now, thanks.
Old Oct 7, 2003 | 02:33 PM
ead94z28's Avatar
Fuse good. I guess I'll have to take it back there.
Old Oct 7, 2003 | 03:09 PM
ead94z28's Avatar
Light and fans didn't go on, on the way to the dealer, go figure. They couldn't figure out why it happened. Maybe just a fluke thing?
Old Oct 7, 2003 | 03:19 PM
Zeueses 97 RamAir's Avatar
pull the fuse
pull the fuse on the inside of the car and see if itn comes on again.. Or go get it checked out first...
Dzmaro
May 7, 2015 09:33 AM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
