95 single cat exhaust for my 96??
Old Aug 8, 2003 | 03:03 PM
Rackmfool's Avatar
I have heard from a few people that the easiest and least expensive way to do a header back exhaust on my 96Z is to use a 95 set up. It eliminates one of the cats and I think it would be a little cheaper in price????
Any thoughts?????
Brian
Old Aug 8, 2003 | 03:10 PM
AsianSensation's Avatar
You will need a S-pipe. Scroll all the way to the bottom.
http://www.thunderracing.com/index.c...yid=1052#T1427
Old Aug 8, 2003 | 04:13 PM
94formulabz's Avatar
Not to mention you can use midlengths Like SLP, AS&M or RKsport which are much better than the hooker, slp, and other shorties out there.
Edit*
I forgot to add, if you are going to get an ORP or anything custom like that made with flanges it might be cheaper for you to just by a 3" mandrel U or 2 90s and have the shop just weld them in. If you are going to try to do everything your self then the Spipe is def the way to go.
-brent
TitoPR221
May 26, 2015 12:20 AM
jasonduaine
Apr 1, 2015 08:09 PM
Fatdog2
Mar 31, 2015 06:50 AM
carl.froehlich
Mar 13, 2015 12:38 AM
Jan 5, 2015 07:14 PM
