Who here has removed EGR/AIR w/ stock manifolds
Old Aug 7, 2003 | 08:22 PM
NVetro's Avatar
Who here removed the EGR and AIR with the stock exhaust manifolds? Was curious what you call used to block the holes on the top of the pass/driver side exhaust manifold and also, who here has ALSO blocked off the exhaust manifold side of the EGR (passenger) and what did you use? Thanks, I searched and found a topic on this but it was pretty general.
Old Aug 7, 2003 | 10:34 PM
lillbush5555's Avatar
there are 2 options for the airpump...you can 1: leave the black pieces on the mainafold(they let air in, but not out) Or U can 2: take off the black things..then unscrew the adapter from the mainafold and get a 3/4 inch galvanizoed pipe cap and screw that on...as fas as the egr...just take it off and get a piece of metal and cut it to match the hole in the intake...and the tube take it off of the intake and put a penny on the end of the hose where it meets the intake mainaflod and screw it back on, Or u can take it off and cut another piece of metal to match that hole...and another 3/4 inch cap...now for the block off plates u CANT use like a coke can that metal is to thin..some people sell them or make it out of roof flashing...it is called valley flashing and u can get it at any good hardware store cheap. I hope this helps
matt
Old Aug 7, 2003 | 10:40 PM
Z95m6's Avatar
i removed mine. My friend had some 22mm plugs that he let me use. I then took my egr tube and cut it and remove the tube from the two brackets. I then welded up the hole in the intake side bracket. I then put a bolt in the hole of the bracket and welded it up too. The bolt works as an alignment for the hole in the exhaust manifold. It was free and worked.
Old Aug 8, 2003 | 12:42 AM
CoUnTryMuZiCZ28's Avatar
I took mine out before a header install so i didnt have to mess with it then, I took the little bolt things that are left after you take the pipes off, to a muffler shop and had them welded shut.. I oredered the block off plates from www.TPIS.com ... Just incase you dont know what im talking about, if you look at the manifolds you can see what looks like 2 bolts(one on top of the other) the very bottom one i took to a muffler shop.. they didnt even charge me to have it done...
DirtyDaveW
Dec 1, 2016 05:37 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
