Will mail order tune give me HP? (PCM4Less, MadZ28)
I have a pretty much stock LT1, I dont have much to spend so I wanted to know if something like Madz28 or PCM4Less mail order tune would give me any HP gains?
yes and better then hpp3 brians the man he did my computer for me as a favor when i sold my hpp3 cause im now getting my cam installed and when he redid it i can feel a major difference in power GET IT DONE
How much of a HP gain should a expect on his "Power Progamming" thats the only thing I will be getting since im pretty much stock.
Question. His order sheets asks "Do you want firmer shifts?" Will that make the transmission go out quicker? Or will it help the transmission?
i think the hpp3 claim like 15-25 hp well pcm4less programming felt like double the power from my hpp3 and as far as the shift hell yeah u would want them firmer u will shift harder and faster
... But I still wonder if shifting harder and faster is good or bad for the transmission...Cause i know i DO NOT have the money when my tranny goes *knock on wood*
how many miles do u have on ur car i had a 95 a4 vert be4 my car now well i have a 94 a4 vert also but i sold that one with out problems but the 95 lasted till 145000 miles till the tranny went out but i did blow some trans mounts like 3-4 times but then i have gone throught 3 trannys after the first one under a warrenty thank god get a m6 cause these tannys hold up good as to the a4 they don't but i wouldn't worry to much about the tanny going till high mileage but the firmer shifts will like make to chirp 2nd gear and ur be glad u got it done it willn't slip as much i think
DO NOT increase shift firmness via PCM......it increases line pressure, and god knows when your tranny will start slipping and need a rebuild. don't increase line pressure unless you have a tranny that's BUILT FOR IT
call brain talk to him ask him what he thinks tell him Will graboyes with the 95 z sent you from jds auto and ask him what most people are doing to there cars and do what he thinks u should DO NOT LISTEN TO ANYONE ELSE BUT HIM NOT EVEN ME he is the man with the plan
Originally posted by Izod
fyi i picked up 11rwhp from a dyno-tune on my car.
(this is after what my crappy initial numbers were).
