Volts from Alt? Original from my '94..
Old Aug 4, 2003 | 11:19 PM
Smokn '94 Z's Avatar
Question Volts from Alt? Original from my '94..
What should I see from my Altenator? What is too low?
Old Aug 5, 2003 | 04:24 PM
Smile
ttt
Old Aug 5, 2003 | 05:12 PM
It kinda depends on the drain. The closer the voltage gets to 12, the less the battery is going to stay charged. Mine runs at about 13v most of the time and that seems to be good enough. A little higher than that would probably be better and more in the
"normal" range.
Old Aug 5, 2003 | 05:22 PM
got_hp?'s Avatar
mine sticks to about 14...........however my headlights dim once in awhile when shifting gears........not sure why.
Old Aug 5, 2003 | 09:33 PM
limige's Avatar
how many amps is stock alt?
Old Aug 5, 2003 | 10:35 PM
If you have one with a plastic fan and a nut that secures the cable to the battery, it is 140 amp.
*Emilia*
May 13, 2015 09:05 AM
Gtpguy
Jan 26, 2015 04:50 PM
Ryabut98
Sep 3, 2002 11:45 PM
JDohn2001
Jul 26, 2002 05:57 PM
JDohn2001
Jul 26, 2002 08:14 AM
