LT1 Cam Question
LT1 Cam Question
I'm building my LT1 for a specific class for SCCA Solo II competition. I can do anything external (bolt-on) but as far as internal mods, none. But.....
Can anyone recommend a cam that pretty much SOUNDS stock but would give me some kind of performance increase? The sound can't give too much away. Hopefully the headers, y-pipe and muffler will mask some of the sound.
Stretching the rule to the limit!
I know cam companies use to make cams that had the same basic lift and duration numbers but had different ramp characteristics. Sort of a cheater cam that has the same basic measurements, you know?
find out the stock cam specs.... like i thing its .480ish/.490ish left and 205/210 duration and a 117 lsa....
get a solid roller with the specs all 15% larger
or maybe even like a cc305 costom ground with a 117 lsa i dunno, just a thought
I really don't think that there is any profit in a cam that is almost like stock.......... So I'm pretty sure no one makes what you are looking for. Sounds like you need someone to custom grind a cam for you. Might try Crower or Crane.
John
John
LOL i dont think he could use a solid roller. I think the CLACK CLACK CLACK from the solid valve train might give it away
Why not just get a custom cam ground that has a few more degrees duration and a little more lift but keep a high lsa. It should be what you want.
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
