If I have a little bit of play in the steering wheel, what needs to be replaced?
It's not to bad, about 1/2 in either direction. The alignment is ok and the tires pressures are good. The only thing done to the front suspension is springs, struts, 31mm sway, hub assembly pass side 9other side still fine) and PST poly bushings, all about three years old. I was wondering if it was in the steering linkage or tie rods? Any ideas, thanks.
Originally posted by 97FormulaWS-6
First I would check your tie-rods... after that you can adjust the pre-load on your rack... which could be some of it if it's not your tie-rods.
I just had the same issue at 92k miles and after checking everything else, it turned out that the rag joint in the steering linkage was worn out. I had to buy a new steering linkage assembly (93-97 f-body: GM Part # 26020775).
If it is your rag joint that's worn here's the options:
- A brand new linkage is $111.29 from gmpartsdirect.com.
- Call Jason Cromer at Sam Taylor Buick (http://www.samtaylor.com/html/parts.html), I bet he has a much lower price than gmpartsdirect.com.
- Check some salvage yards as I've heard of some people getting a used one for like $15.
- Replace the rag joint with the "rag joint eliminator" from Unbalanced Engineering ($30) - http://www.unbalancedengineering.com/Camaro
would that introduce more vibrations and such through the steering wheel?
Agree about the rag-joint. I had a fair amount of play in the steering wheel. I even had to argue with the dealership that it had a problem, but ultimately they agreed & replaced it. I think they said some rivots had become loose.
Thanks, I appericate it. I looked at the tie rods, they seem unbent and firmly in place, as do the wheels themselves. I do have uncoated headers though, so maybe it's the rag joint. If it is, how hard is it to replace and if so, do I need a new alignment? Also, I was thinking of installing bump steer tie rods. If it is the tie rods, would this correct it, or just an addition to the rods?
Hope this helps.
ro2207
Dec 4, 2014 06:18 PM
Jul 4, 2005 05:00 PM
