lame question, removing the oil pressure sensor ('95)
After looking at shoebox's pics, I still am unable to see how to replace the sensor. Does it unscrew from the block itself or is it removed from the right angle adapter (which is screwed into the block)
Sitting here at work, so I'm unable to look at it right now... just looking for some input..
Ok, so just the black plastic cylindrical portion (the sensor) unscrews from the second right angle adapter (looking at your picture, it looks like there are two right angle adapters in series)
Cr#p...
Why does just about everything on these cars require a "special socket" or a wamboozle extension, or optispark installation instructions that read like directions from a bottle of shampoo: " install the new optispark and enjoy. Repeat as neccesary."
Anyhow, enough venting, shoebox, can I pick up this fancy dancy socket at any ol'e car parts store or is it a dealer item?
I just replaced/tightened mine yesterday...the socket was like 8.00 but I didnt have enough room to get back there so I just ended up being careful with a cresent wrench...
Now shoe I got a question for you...I only had one fitting back there...the one in the block...and the sensor was threaded into that. This should be accpetable shouldnt it?
I just tried the crescent wrench earlier this morning, but couldn't get it in there. Darn ASR box and cables on the driver's side valve cover gets in the way. Might have to temporarily move it.
Use some telfon tape on the threads of the new sensor.
The saga continues...
I was able to replace the sensor, with the socket, a universal and extension. Piece of cake.
Hoewever
Now the gauge is telling me I have a lower pressure than I was showing before the change. I was getting 20 psi at idle warm. Now it 15 and maybe even lower.
Any thoughts? air bubbles, sensor not screwed on tight enough (leaking) new sensor bad.
Little nervous now, the results are the exact opposite of the intended effects..
Hoewever
Jul 4, 2005 05:00 PM
