question about the fan
Old May 8, 2003 | 04:13 PM
slverbullet's Avatar
i have a manual fan switch on my car and noticed today that when the fan is on high, only one fan works and when theyre on low they both work. is this normal? if not, what can i do to fix it?
thanks for any help.
dave
Old May 8, 2003 | 04:29 PM
It all depends on how you wired up your switch.
Old May 8, 2003 | 04:39 PM
i used the wiring harness on the passenger side under the hood. i forget what letters i hooked to, but i dont think that is relevant, is it? if so i can go look. ive had it hooked up for over a year now. and in all honesty, this is actually the first time i paid attention to it. it didnt sound any different, i just happen to be under the car looking for a freon leak and happened to notice it.
Old May 8, 2003 | 04:48 PM
Did you follow the wiring diagrams that are posted many places? Both relays have to be grounded at the same time for both fans to run at high speed. Grounding them separately will get you both fans on at low speed and only the RH fan on at high speed.
Old May 8, 2003 | 04:58 PM
okay, the setup i have is this: both splices lead into the car into a three position toggle. the toggle has three prongs on the bottom. the two outside prongs are for the splice wires and the middle being the ground wire. so i have only one ground wire going out.
Old May 8, 2003 | 05:01 PM
i see what your saying though. in my setup, i'm grounding them separately. okay, so how do i go about grouding them both when i have the high switched on?
Old May 8, 2003 | 05:33 PM
okay, my brain is smoking. the only way to have both grounded is to have two seperate switches. the first switch connected to the "low" splice and ground. and the second switch would have coming into it the "high" splice and the ground from the first switch. does that sound right? thanks again for your help. i appreciate it.
Magenta_Hearts
Mar 29, 2017 08:54 PM
linz
3rd Gen / L98 Engine Tech
Apr 7, 2015 11:49 AM
ChrisFrez
Mar 1, 2015 01:33 PM
ChrisFrez
Feb 22, 2015 08:47 AM
ChrisFrez
Feb 15, 2015 08:12 AM
