View Full Version : Parts For Sale
- LT1 Engine,Transmission,ECU, and wiring harness
- VERY clean Stock LT1 Intake, Edelbrock LT1 52mm TB, Set of 8 Probe Forged Pistons
- Brand New Trickflow 62CC LT1 heads. 1240shipped
- FS:1995 T-56 with bell housing and stage two clutch
- automatic 97+ center console
- F-Body LT1 Procharger Kit w/ Intercoolers
- 96 Z28 shifter plate, boot, shift pattern.
- LS6 intake for sale
- Parts I'm selling
- 32k 10 bolt (02 m6 car), LT1 backing plates, LT1 auto radiator, LT1 lifters
- 5" auto meter tach for sale
- Fourth Gen F-Body Parts
- FS: Torq Thrust IIs
- throttle body and water pump for sale
- LS1 Aluminum DS and Steel LT1 DS
- 2 17X9.5 Painted ZR1 Wheels/Nitto DR
- For Sale MadZ28 PCM
- Sony CDX-FW570 HEADUNIT...MINT!
- steering wheels/v6 springs/HVAC!!!
- WTT42lb inj
- LT1 and SBC parts for sale!
- Moroso Oil Pan LT1
- Camaro Leather Interior
- Sand blasted perfect LT1 bell housing
- 96-97 PCM-tuned for gm847,6speed,3.42s,30#inj,ect
- t-top sunshades charcoal grey
- FS: 95 Trans Am interior pieces..all of them!
- parts for sale/lt1
- New AFR 8017 Dual Valve Springs .600" Lift
- wildwood lightweight drag brakes, bmr kmember, ported intake mani
- F/S: OBDI PCM w/LT1-Edit & AKM cable, OBDII PCM
- lt1 parts and more for sale
- FS: 35 spline axles, spool
- LT1 Parts and more
- front end cover/mask
- custom enclosure for 10" subs
- ONE camaro 17 inch 10 spoke and tire and center cap
- Brand New LT1 spec BILLET flywheel 250 shipped
- Built LT1 4L60E
- OBD1 PCM $48 shipped
- lt1 block .030
- lt1 long tubes and lt1 block
- gauging interest on sweet nitrous setup!
- Red Billet Shift Knob W/tail
- LT4 Top End and a various bolt ons for LT1's
- trans am high rise hatch
- Energy Suspension Poly Torque Arm Bushing New
- LT1 AFR 190 Aluminum heads
- 1994 T/A Tail Lights/center section
- Chrome Y2K C5 Wheels
- T56 trans with short shifter
- Garrett Airesearch turbo, rocker arms,nitrous spacer,oil pressure gauge with pics
- Brand new stock oil pan for a LT1
- FS: 93-97 Pontiac Firebird/Formula nosemask
- 383 LT1 Stroker - NEW
- Stock steering wheel for sale
- Bilsteins 1LE springs and lots of performance and stock parts off my 96 WS6
- NIB LT1 OVC Wire Kit
- NIB Holley 58mm T-body
- Almost New Clifford 450 G5 Alarm Complete W/rem Start And Prox!!!
- Xpipe
- Ram Power Grip HD Clutch kit Brand New
- FS 04 GTO Exhaust
- BMR Strut Tower Brace
- 8" ATI 4500 stall
- Stock 6 speed shifter
- 3rd gen firebird wheels and tires
- FS Hoosier 335/35/17 slicks
- NIB Scorpion 1.5 roller rockers 3/8 stud
- gauging interest: MF catback
- LT1 stuff...Flowmaster, Complete 10 bolt rear, AC stuff, Scorpion 1.5 RR...lots more
- forsale lt1 t-56 swap
- F-Body EGR valve F/S
- FS: Trans Am full Dash and Dash pad
- Camaro Salad Shooter Wheels/Tires
- Trans Am 6speed Center Console Complete
- 1994 T/A Tailights/center section
- WTB Alt relocation kit
- Procharger 12 Rib Setup
- FS:QA1 Double adjustable rear shocks
- 1.6 roller rockers F/S
- lots of parts for sale cheap cheap pictures
- NOS Kit, Purge Kit, Shifter Knob, Lou's Short Stick, 375+ & Misc
- couple stock LT1 parts
- Power Steering Pump/Halo Headlights
- Complete LT1 383 solid roller carbed
- GMS LS1 MAF sensor
- NIB custom ET Performance 245's
- Brand new LT1 SPEC billet flywheel 265shipped
- Fidanza Aluminum Flywheel for LT1
- Spec Stage III Clutch, CHEAP , low miles
- BMR lower A-arms (both)
- FS: Coated 94-95 LT1 Pacesetter LT's
- 94-97 vented opti 125$ perfect condition
- Cheap LT1 heads, etc.
- Four Dayton 255-45-17 Tires - $100obo.
- 10 bolt 3.42 rearend
- LT1 engine harness, computers, Cams, and old school longblock
- Stock Obd1 Pcm A4 $55 Shipped
- brand new richmond 4.10 gears never installed
- LT1 Granatelli G2 CAI
- 96-97 Hub/balancer..perfect condition(picture)
- 383 Block For Sale LE4 Cam
- F/S 02 LS1/4L60E - 22K miles
- Hypertech Power Programmer 3
- all my 396 motor part,afr heads,lt4 instake
- 95 Z28 Parts
- lt1 parts sale
- 58mm LT1 Intake - Powder Coated Black
- for sale LT1 and old school parts
- new summit high torque starter $90 shipped
- UMI Relocation Brackets, LCAs, and Panhard bar, BBk 52mm TB
- spoiler, wheels, corners, pcm
- Custom Built Box w/4 10s 1200w amp, 1farad cap
- Stock TB, lifters, rockers, pushrods, MAF from 95 Z28
- Tires,Scanmaster,OBD1 computer,poly motor mounts
- NEW Gm Timing Set, MSD Opti
- 3rd Gen Trans Am Ground Effects
- Thinking about parting out 96 TA roller(doors,wing,interior ect)and selling frame.
- LT1 PTK hotparts 85% complete
- New GM 8.5" and 8.25" 3.42 gears
- FS: SVO 30#, G2 CAI, Aeromotive AFPR, 95 Hypertech...
- MSD Windows Switch
- AC Delco Oxygen Sensors
- TB For Sale
- Alpine Head Unit For Sale
- A Few LT1 Goodies
- 1992 camaro dash pad
- 98+ eibach sportlines brand new
- Energy Suspension 4thgen master set new
- Big List of LT1 parts for sale...
- LT1 sale *big*
- new 96-97 timing cover, chain and used gears for sale.
- WTT: My T-56 for 4l60E
- 96 lt1 and 4L60E for sale
- nitrous kit
- Custom Blower Cam 227/238/115
- Ported & O-Ringed AFR 190 LT1 Heads
- accel 30# injectors for sale or trade, and a set of fog lights
- 10 bolt disc rear for sale
- 2 LT1 cams, LT4 & Solid roller CHEAP!!
- 93-96 camaro pillar pod, cubby pod and more
- Eibach Pro Kit
- 1996 Hypertech HPP3 for sale
- 3.73 gears with auburn posi, excellent!
- (2) Hoosier Drag Radials 335-35-17
- FOR SALE! (2) 275/40/17 tires, (2) 335/30/18 tires, and ten spokes
- ALOT of camaro/firebird/vette rims wheels tires *cheap*
- Borla Cat Back For Sale
- spoiler, tb , airfoil , plug wires, F.A.S.T
- FS Stock LT1 stuff
- Block For Sale .30
- Hinged bottle brackets and a wet kit
- 82-92 SLP 1-5/8" Coated Headers w/AIR and install kit FS
- FS: Eibach Pro Kit Springs.
- Tuned PCM
- For Sale: 19x9.5 Aza Z-1 Black Center Wheels
- Accel DFI Gen 7 setup $850
- FS: BAd ass set of rims and tires. New the st up was abt 2000.00 Cobra R look alike
- 96-97 hub and balancer PERFECT CONDITION.
- F/S Autoprom & LC1
- Billet Specialties Centerbolt Valve Covers!
- 2 LT1 PCM's (pics)
- NX Quad Gemini Plate, Extra Bottle, Brackets, etc.
- LT1 Solid Roller Valvetrain Package
- Tall perimeter bolt VCs and adapter plate
- Sand blasted, LT1 Red intake/polished rails/tb
- WTS: 93-97 RS Body kit
- 95-97 Msd Opti New!
- Wtb 93-97 Ws6 Hood
- 95' Camaro Z-28 Body Parts Cheap Look!!!!mia,fl!!!!
- F-body Lowering Springs
- LT1 Race parts...
- Stock Steel Driveshaft=$65 shipped
- Z06 injectors, throttle body, heads...etc!!
- Qtp 3" Elec Cut-out & S/s Tube W/switch & Harness!!!! $85 Shipped
- FS: NOS Wet Kit $250.00
- Corvette FRC's black with red lettering!!
- OBD2 scan tool with cable
- 4th Gen Camaro houndstooth seats
- new summit high tork starter $110 shipped
- dash bezel 95 formula cheap!
- 98-02 front end conversion(bumper cut out for turbo) for sale CONNECTICUT PICKUP ONLY
- for sale 3inch mufflex y pipe+4 boral xr-1
- 94 LT1 stock parts..
- underdrive pulley,front adjt control arms, front swaybar, jetchip
- lt1 intake,egr,injectors,map, etc,etc e-bay
- camaro firebird rims for sale
- 374 Casting's Alum Heads With Hardware $240 Shipped!!!!
- Nu-tek Ported Canfield Heads
- MSD Ignition coil,Front and Rear lights covers,Stock Shifter.
- A/C condensor/Dryer/Lines
- Many LT1 F-Body parts (starter, alternators, leather, doors, hatch, etc)
- msd coil packs for sale
- Corsa Exhaust
- front drag springs on newer struts
- Misc Ls1 Parts F/s
- 95 A4 Trans Am wiring harness/computer
- 4l60e
- LT1 bellhousing sandblasted perfect. 150$shipped
- Lt1 auto to t56 swap parts and street twin clutch.
- 2004 GTO LS1 Throttle body on ebay
- lt1 programming cable/diagnostic cable
- 95 firebird auto stuff
- LT1 wiring harness and computer
- NX GM EFI nitrous kit with lots of goodies!
- Stock LT1 valve covers with new gaskets $25
- Big Summer Sale Going On Now!!!!!
- 1994 Camaro / Firebird Shop manual
- LT1 140 amp alternator 93-97 f-body
- Brand new Accel Vented Opti 95-97
- FS. LT1 engine/1 year warranty low miles.
- FS: NEW! 42# Lucas Injectors
- 94-95 OBD1 PCM 110 shipped
- under the dash heat/ac vents
- FS: SBC Edelbrock Victor EFI Intake Manifold
- garage sale
- F.S. LT1 hooker shorty headers
- LS2/LS6 intake manifold 4 sale
- 96-97 Ws6 Ramair Box
- Rock On Stage 4 Tranny
- C5 corvette wheels
- 4l60e and headlight motors
- Stuff for free
- Summer Sale On Now
- FelPro 9966PT LT1 Headgaskets
- camaro hood
- LS1 aluminum drive shaft $120
- Complete Delteq system W/wires
- FS: LT1 Street Twin
- Cc306
- LT1 Vortech with cogs and Mondo bypass
- Nitto Extreme II 275-45-17s
- my rockers FS on ebay
- New Forged 388 short block on Ebay
- 4th gen stuff for sale - needs to go asap
- 275/40 and 285/40 17's for sale
- Many parts for sale! gears headers heads intake
- 1 pair of LT1 heads casting643's and a bare lt1 block
- LE2 cam
- LS1 Power Steering Pump Resevoir
- FS or T:COMPLETE nos dry kit
- Firebird Hatch For Sale
- FS Stock LT1 front sway bar
- LS1 parts Windshield, Z06 MAF w/wire conv. Fog Lt, '98 GM Service manual sup
- Two sets of wheels and tires,
- 5200 miles; LS1 engine for sale
- Melling Oil pump + ARP driveshaft F/S
- For all your F and Y body needs
