Move Forum Jump menu Up?
I do not know if it has been asked before, but is there any way we can get the Forum Jump menu at the bottom of the page to move up to the bottom of the last post? It would help out a lot, because after I am done reading all of the posts, I either wasnt to reply to the post, or go back to the forum I was in, and instead of hitting back, I use this so it is updated with new posts (doesnt do that when you hit back on your browser)
Just wondering, it would make things a lot easier.
Cameron
Cameron
Re: Move Forum Jump menu Up?
Well I guess what I was asking is can it be moved above the quick reply box? Judging from your answer no, but just thought I would ask
Thanks for the reply
Cameron
EDIT: To be more descriptive, the only reason I continued to ask this is because the forum jump bar is so small, it really wouldnt move the quick reply box down much. Just a thought.
Cameron
Here's a helpful hint...
In the upper right hand corner area of the Quick Reply box, you will see a little gray square graphic with a red blocky arrow in it. Click it, and it will either expand or contract the Quick Reply box. It is cookie-enabled, so it should remember how you left it each time you change it.
There are a few like this, such as the "Posting Rules" box to the left of the forum jump. You can also do this with the major sections of the forums. For example, if you never use the regional sections, you can hide all of it but the title bar. Give it a try!
This should help you out, anyway.
cmsmith
Apr 11, 2015 09:33 PM
NewsBot
Feb 6, 2015 05:00 PM
