Jason, using Moxilla and this board
Jason, you help me out last week, by using mozilla (firefox). Well I got it all working, but when I use it on this board I have one major problem. When I respond to a thread, the window you use to type the responce is only half as wide has the box when using IE. Do you have this problem too?
Re: Jason, using Moxilla and this board
Perhpas there is a setting I can change...I'll look into it.
Another problem with mozilla (firefox)
When I get a private message, and I click to open it in a new window, a new window does not open up.
Originally posted by JasonD
Yes, I have that same problem. I am not sure what causes that. I think it might have to do with the pop-up blocking. When I use PMs, I just go into it via my User CP.
P.S. I just send you the money for StngStlkr avatar that he won in my contest.
Oh, you prob right about the pop up blocker. Not a big deal.
BTW...your sig is lame.
PM pop up problem fixed. Go to options then to "web features" and you can add www.camaroz28.com to the sites that you want pop-ups to be allowed. Then when you get a PM, a new should open....In theory.
on my firefox, in the bottom left corner just above the start button is a blue picture. if you double click on that you can achieve the same effect by taking the current website off the pop up blocker. (only works if its blocked pop ups from the site already.)
and yes i too have a bigger dialog box for text. thanks.
