1995 z28
1995 z28
I have a 1995 z28.
Car was running fine until yesterday.
If you drive it fairly easy it runs fine.
If you get into it fairly hard when it shifts to second gear it dies.
It will refire after a far amount of cranking.
Don't know quite where to start with this issue, any help would be appreciated.
Re: 1995 z28
Is the engine stock, or modified? If modified, what has been done? How many miles on the engine"
Have you scanned it for codes, and checked the fuel pressure? When you are trying to restart, during the "far amount of cranking", do you have spark to the plugs?
Does the car still have a cat? Could it be plugged up?
Re: 1995 z28
get a fuel pressure gauge. It should be 43.5 with the vacuum line removed from FPR (or around 37 psi with it on). If it is good at idle...rev the motor to see if it drops....it should not. Ideally the gauge has a hose long enough on it to tape gauge to wond shield. If at "sustained" WOT it drops...fuel pump is failing
You mention it will run OK at light throttle but die when you get on the gas...this could be due to low fuel pressure from a fuel pump failing...or a very clogged fuel filter
rule out a fuel pressure first and if that checks out move on to ignition
Re: 1995 z28
You have to test the fuel pressure with the engine under load, out on the road, at 4,000 RPM. Tell us the numerical result... not "all checks out".
I'll ask again..... have you scanned it for codes?
Re: 1995 z28
I scanned for codes. No codes. Fuel pressure under load on the road was36 psi. At 4000 rpm it shut down going down the road. I went ahead and installed a new fuel pump and filter. Did not change a thing still shuts down at 4000 rpm sitting still or going down the road. I am assuming now it is ignition?
Re: 1995 z28
because now you're having the same issue without any change.
Re: 1995 z28
Ok. Here's an update. Now it will die at idle in park sometimes or not till it hits about 4000rpm. It's sporadic. When I try to immediately refire there is no spark. But after 10 or 15 minutes it will fire right back up
Re: 1995 z28
Have the ICM tested, making sure the shop gets it good and hot.
Fuel pressure at WOT, high RPM should be at least 40 PSI. Part throttle rail pressure will drop proportional to intake manifold vacuum, as described in an earlier post.... e.g. 36 PSI.
Re: 1995 z28
Let me retract my last statement. Icm did not fix it. Ran great in the shop. Took it out for a drive. Didn't make it a half mile and it died. Now the problem is more sporadic. Starts and dies. Then it might start and make it a few hundred feet then die. Or it might start and go a couple miles then die. It's all over the place. Like the problem is getting worse.
Re: 1995 z28
Check to see if the ICM is getting the signal from the PCM to fire the coil.
Courtesy of Shoebox
4th Gen LT1 F-body Tech Articles
What scanner are you using to try and pull codes?
Courtesy of Shoebox
Re: 1995 z28
This sounds like an opti on it's way out if you've ruled out the easy to check ignition stuff (ICM, Grounding etc). Because the ICM made some difference but didn't solve the problem I'm leaning towards ignition/electrical related for sure.
I would rule out wire arcing, failing spark plugs etc as those issues would be a more consistent problem (it would run rough all the time or at certain rpm and loads), if the ICM / Coil is good that leaves you with Opti.
