LT1 F-body turbo setup
Old 02-14-2017, 12:03 PM
Jason Short's Avatar
This isn't your average turbo setup for a F-body. I also understand that there are cheaper alternatives out there, but this is probably one of the top 5 LT1 turbo systems ever designed in my (bias!) opinion.
The layout was designed by me and fabricated by LT1 Boost (Jon). Everything is brand new for the most part and has only been mocked up on my 1997 SS. The turbo is used but has been sent back to Precision Turbo for inspection, verification, and new seals. The unit has zero miles since being returned and the paperwork from Precision will be included.
The layout of this turbo setup is very unique and the only system that I know of that allows the radiator to be utilized in the stock location, retention of all factory accessories, retention of front swaybar, and a downpipe that goes through the K-frame on the passengers side (zero loss of ground clearance). The only thing this kit does not allow for is the A/C. There are zero compromises other than that and the routing even allows for easy plug access. The hotside is completely stainless and properly TIG welded using backgas.
Please refer to the build thread for mock up pictures and a TON of information about this system: https://www.camaroz28.com/forums/for...-short-844583/
I'll add more details about the system over the next couple days.
Everything shown in the pictures is included with the sale.
$4500
Jason Short is offline
Old 02-14-2017, 12:04 PM
Re: LT1 F-body turbo setup
Old 04-14-2017, 12:57 PM
87Aerocoupe's Avatar
Holy "Sugar Honey Iced tea" what size turbo and how much rwhp is the kit designed for? Is a FMIC included with this also?
87Aerocoupe is offline
Old 04-19-2017, 08:02 AM
Haha!
It's a Precision 76GTS turbo (76mm). You can easily make 800rw with this setup/turbo. Quite a few guys have made over 900rwhp with a 76GTS.
I do not have a FMIC. That is one of the only components that I don't have for this setup.
Old 06-09-2017, 11:41 AM
sleeperZ96BT's Avatar
What a beautiful kit Jason!
sleeperZ96BT is offline
Old 12-11-2017, 11:52 AM
timelord's Avatar
Jason,,,,you have mail!
timelord is offline
Old 02-15-2019, 09:28 PM
Hey Jason do you still have this kit and if so how much for just the hotside?
cause4panic
12-16-2008 08:39 AM
JohnnyPappis
02-27-2008 05:04 PM
JohnnyPappis
Middle Atlantic
02-23-2008 08:00 AM
Why Try
08-24-2007 11:36 AM
jerminator96
10-28-2006 09:16 PM
Quick Reply: LT1 F-body turbo setup
