Retrofit question. I think I may have something not 100% right
So I have an Lt1 in '69, the way i've had it setup is the following connections have always gotten power on key.
c100 a pink injector #9
c100 d orange power feed from pcm fuse 8 to pcm
c100 g pink power feed from ignition fuse 11
c100 k pink power feed from ignition fuse 10
c105 b pink power feed from injector fuse 10
c230 g pink power feed from pcm ignition fuse 5
It was brought to my attention that they should be receiving constant power.
Now I'm thinking the ones that should be receiving constant power,
are
c100 a pink power feed from injector #9
c100 k pink power feed from injector fuse 10
and the one that should be reciving Key'd power (ie to turn the pcm on and off) are
is this correct?
Thanks
-Brahm
are
is this correct?
Thanks
-Brahm
Brahm.. here is what I have from the 1994 F-Body GM service manual...None have constant power from Batt
C100-A from fuse 9 to injectors 2,3,5,8 hot in Run, Bulb Test or Start
C100-D Traction Control Active from ETCBM (Elect Brake TC Module) A16 to PCM C11
C100-G Ign fuse 11 Hot in Run, Start, Bulb test to Coil and ICM
C100-K from fuse 10 to injectors 1,4,6,7 hot in Run, Bulb Test or Start
C105-B Cant find a 105 connector C100-B is AC relay pick from PCM B6 to AC relay B5
C230-G From fuse 5 Hot in Run, Start, Bulb test to PCM pins D3 & B30 and MAS pin C
ok I think i may have found my missing wire, I'll find out tonight.. 210 Orange, should be receiving constant battery power. So all these stay the same. Is there anyway to test and make sure it's saving it's memory (something I can see via a datamaster?)
Thanks
-B
Thanks
-B
what a mess, the motor is a 93 that got swapped to a newer pcm so I don't have to burn eproms, the harness is a 95, and I believe the OPTI is a 94...madness.
Almost got the re-wire done. I just need to Relay the meizer water pump, put some inline fuses for the PCM, Water Pump, hook up the lights to auto meters clean it up all up and secure it behind the dash, and if I have time find where the heck the body harness wire went for my fuel tank sending unit.. I swear I had that thing hooked up at one point nothing like going on a 7-8 hour drive threw the desert with a 10gallon fuel cell, and no fuel gauge..hmm.. should I pass this gas station or just double check to be sure... hahaha
On the list after that, striping all unused connectors and plugs I can't wait to clean up the engine bay.
Oh, and Rob thanks again for your site, If it wasn't for you I never would have got this thing running! I swear I went cross eyed staring at those diagrams and what not. Next time painless wiring kit!
Alright, update on my progress. Really went to town rewiring the car this past week. After all was said and done i'm getting 13.5v in the PCM w/out lights, but when I turn on my headlights It drops to around 12.5, after a bit more investigation it looks like I'm loosing a FULL volt from the alternator, to the battery, and another half volt or so from the cut off switch back up to the engine bay.. Now that my PCM wiring is all squared away (I think). I need to re-wire my remote starter solinode and battery.
Regardless car drove pretty darn good, took her about 1000 miles and got in 4 passes @ Barona 1/8th Drag Strip with a best of 8.29 @ 82.3mph w/a 1.8 60ft. While nothing amazing, not shabby for a motor that is setup for power adders with none, and not having a tune.
So with that said. I logged my runs. If any of you care to take a peak, and give me your feedback, or thoughts on where to improve. I would be grateful.
http://www.brahmgoodis.com/xfer/logsbrahmbarona.zip
Many of the errors cleared out once fixing the wiring, but I did get an odd 02 error.. I fixed this by finally sealing off my evac system, I think but didn't clear the codes until the drive home. On the 400 mile drive back I had nothing but the lamp, error and one other non-important one.
First time I've seen a data log more than 1.5 hours in length. Were you shutting the engine down at all? Every so often it drops out of closed loop, but that happens after the engine run time resets to "0". Or does it just lose power to the PCM at times?
You have 6 codes, including one for failure of both O2 sensors. The others, CCP, VSS, MIL, and brake switch stuck on are probably relate to the install. There are a lot of "data errors" indicated. That can happen when there is electrical interference with the data wire or you logging cable.
You are getting huge knock retard spikes (12 - 14-deg), but some of those are tied into the data error flag. When its cranking for restart, the system voltage drops as low as 7V. TPS voltage at closed throttle is 0.84V, a bit on the high side. Might want to check the throttle blades to make sure they are closing all the way, or slot the sensor so it can be rotated to bring the voltage down toward 0.65V.
In PE mod (~WOT) the O2 sensors are indicating over 1,000mV, indicating a very rich mixture. Yet there are other cases where its in open loop, and running on Cell 18, and the O2's in PE mode are in the mid 300 mV's. Too lean.
MAP at idle seems to be in the 50-60kPa range. What cam are you running?
Probably more, but that's all I had time to look at.
The VSS issue is gone now that I was able to fix the volts from what it was before, once I cleared the computer it didn't come back.
The CCP is still there and the Lamp, but I was thinking about disabliing those in my tunercat file.
The break switch stuck is a new one.. No clue whats going on there, maybe it grounded on something?! I don't have it hooked up.
The data errors are what have me worried, I never had that issue before a few weeks ago and now it's pretty constant. It seems to be a bit better since I improved the volts in the pcm, but I have no clue what is going on or how to fix it. At this point in time, I'm nervous about uploading a new tuner cat file as I don't want it to drop connection during the upload and from what I understand...ruin the PCM?.. Is this possible, and correct? What's the best way to resolve this?
-Brahm
Pulled down the current PCM tune, and did the following.
On the Switch table, I Removed error 11, 26, 37, 38
On the Constant table, I Changed the Cylinder Volume to 727.17 (it's a 355), fuel cutoff 1st gear up to 6650, 2nd-6th to 6657 (it was bouncing off the rev @ 5700-5800), and the appropriate fuel return.
With that said I don't know what else to do really, I've been looking at the BLMs, ect.. I read this.. http://www.lt1howto.com/articles/pcmtuning.htm, and it seems like if I really want to learn to tune the car I need a wide band 02? is that correct, or is there a lot I can do with what I have first?
As far as knock what should I do? Try an lt4 sensor?
Thanks again,
Oh, and if you guys check out that log file, I know it's big but if you just look at the last "hump" that is the 8.29 pass, so the best it performed.
Thanks again,
I was going to get some vette covers but my fuel lines are altered for AN lines and they won't fit with a bit of chopping.
Thanks, and likewise. How did your swap go? How's your engine bay turnout.. mine is a CLUSTER of wiring haha.. I'd love to see some photos of somebody who managed to clean it all up.
I was going to get some vette covers but my fuel lines are altered for AN lines and they won't fit with a bit of chopping.Not as clean as I would like. I would probably do the wiring a little different next time.
Brian
