Zaino is sub-zero temps...
Old Dec 13, 2003 | 09:42 AM
1996 | Z28 SS's Avatar
I've only ever used my Zaino is the summer so far... but now it's winter.. it's actualy -10 outside (celcius of course.. so thats what 14 *F?) anyways... is there any negative effects to using Zaino is this kind of temperatures beside it will probably take forever to dry? Right now the suns out and I'm thinking I'll bare the cold to get a good coat on. Thanks
Trevor
Old Dec 13, 2003 | 10:30 AM
Brent94Z's Avatar
Super Moderator
Moving to the Show and Shine forum...
Old Dec 13, 2003 | 02:09 PM
KevinSS's Avatar
I have never applied it lower than 32F , since you are taking it to the extreme, I really do not know. You might want to email Sal, I would think that the polish might freeze solid at 14 or 15 degrees.
Old Dec 13, 2003 | 04:11 PM
Well... I waxed her up already.. No problems what so ever. Well.. actualy, now that I think of it.. the last bit of wax that I was rubbing off seemed to be slightly harder.. not much though. Just took a little extra pressure. And I also sprayed on the Z6 afterwards.. was a little tricky because if I put too much on at once.. it very, very quickly froze/dried right up. So I just took a little extra time.
Zaino = The best
Trevor
Old Dec 15, 2003 | 07:17 AM
hcvone's Avatar
I know someone that had it freeze on their car, it was a mess and had to be washed off several times to remove it, if you had no problems you were lucky.
Old Dec 16, 2003 | 05:50 PM
hmmm... how long did he let it dry for? And how cold was it?? It was -10 but the sun was out.. so through out the day it probably got up to -5 and was even warmer in the sunlight directly. Maybe that helped.. but I didn't let it sit too long... 20min maybe. And nothing froze at all.. not as easy to take of as it is during the summer of course but not by much though...
Old Dec 17, 2003 | 06:12 PM
Kevin V 2002 SS's Avatar
If you were in sunlight that helped warm up the body a little. Personally, I'd recommend staying on the 32*+ side just to be sure AND use the ZFX to help the drying due to the lower temperatures.
Old Dec 18, 2003 | 07:17 AM
Drumhawk's Avatar
Re: Zaino is sub-zero temps...
Trevor
I don't think it's a good idea unless you drive your car through the winter. My hawk is off the road for the winter in my garage. I open the door into the house connecting the garage to warm it up before I apply zaino. Just my opinion from a fellow canuck.
Old Dec 18, 2003 | 11:48 PM
94bonefast's Avatar
Re: Re: Zaino is sub-zero temps...
B]I open the door into the house connecting the garage to warm it up before I apply zaino. Just my opinion from a fellow canuck. [/B][/QUOTE] [/B]
Yeah the old lady doesn't like it when I do that trick.[
Old Dec 19, 2003 | 01:59 AM
Drumhawk's Avatar
Re: Re: Re: Zaino is sub-zero temps...
[/B]
Yeah the old lady doesn't like it when I do that trick.[ [/B][/QUOTE] I don't have an old lady and if I did she better not tell me to waste heat in the garage. I'll pay the extra few bucks hydro no problem. BC has one of the lowest hydro rates in North America and there hasn't been an increase in ten years but they want one now.
Old Dec 25, 2003 | 03:45 PM
Big Red Jim's Avatar
I think 20* F is about as cold as I've ever applied Zaino. If I recall, it took nearly an hour to dry.
Jun 5, 2015 10:16 AM
ChrisFrez
Mar 29, 2015 09:43 PM
squirrels
Sep 24, 2001 02:31 PM
klaymon
21
Sep 19, 2001 11:11 AM
Lt1Diablo
Sep 14, 2001 12:47 AM
