Zaino Streaks
Subscribe
Aug 13, 2004 | 02:53 PM
I clayed the car today then washed it dried it and Zainoed. First Z1 (a couple years old but kept inside), then Z5. Z5 was on the car 1-1 1/2 hrs. Wiped off the Zaino and now there are wet look streaks. Kinda when you dry your car and can see some of the water left before it dries away. Will these go away with more coats of Z5?? Plan on atleast 2 more coats, or do I need to strip it off and start again? My first time Using the Z5. On a show car so I want it as close to perfect as I can get it. Also I am going to let it dry over night and try wiping it again tomorrow.
Reply
Aug 13, 2004 | 04:58 PM
Re: Zaino Streaks
No need to start over, just try applying the next layer thinner. I usually get 3-4 coats per ounce.
Reply
Aug 13, 2004 | 09:01 PM
Re: Zaino Streaks
Just mist the paint with plain water and buff off with your Z-6 towel and it should even out the streaks, it could be you used uneven pressure with your hand when you applied it and cause the streaking...
Reply
Subscribe
