zaino Q?
zaino Q?
Its been about a month since the last coat of Zaino on my car (only 1 coat at the time) Can I just slap on another coat after washing or do I have to put Z1 on first or us ZFX with it. Or is one month ok without using the other stuff, just Z2?
Re: zaino Q?
Ok, first, you do not use Z-1 AND ZFX both, you either use the two step Z-1 system or the one step ZFX system but there is not reason to use both systems at the same time.
That being said, if you are using the Z-1 system, Z-1 is applied once per six months and in between that time you can add as many coats of Z-2 on the paint any time you like as long as the car is clean.
You can use Z-2 without it being mixed up into the ZFX but if you want to do three coats in one day you will need to have it activated with ZFX for instant curing and for it to dry much faster.
Re: Re: zaino Q?
Your second paragraph answered my question perfectly.
And I use the 3 coats with ZFX whenever I detail a car.
Thanks for the info. Time to slap on a coat of Z2.
ChrisFrez
Mar 29, 2015 09:43 PM
squirrels
Sep 24, 2001 02:31 PM
Lt1Diablo
Sep 14, 2001 12:47 AM
