What is the BEST way to.....
This might sound like a dumb ?? What is the BEST way to clean the engine???
Thanks,
Mike
98 Camaro Z28 (blue)
Loudmouth exhaust
LS1 lid
K&N filter
C:\My Documents\98CAMARO2.jpg
Thanks,
Mike
Loudmouth exhaust
LS1 lid
K&N filter
Engine cleaner from the autoparts store and follow the directions.
Oh...and I'm not trying to pick on ya or anything...but in your sig...you have a link to your harddrive for your photo...
"C:\My Documents\98CAMARO2.jpg" I don't think anyone but you is going to be able to view that photo.
-Mike
-Mike
One spray bottle of simple green, a heated pressure washer, and go to town
Wet and then spray the bay with simple green (avoid alternator and ignition components, also the computer). Let sit for a few minutes, and then take the pressure washer and blast it. It will look brand new if you did a good job!
I second the simple green, or better degreaser. Make sure the engine is cold when you spray it on so that it doesn't bake on. If you're worried about spraying water on the engine, after you spray the degreaser and let it sit, start the engine and let it run while you hose it off. Leave it run until it dries.
