First off, i have a huge problem. at 65-70 my interior is trmbling like hell!!! all the fuxkin plastic rattles and i was wondering if anyone knew where i would be able to find a place that sells the specific screws that each interior part needs so that i can ighten everything up....
Has anyone done this to a fourth gen camaro?
or maybe this is the wrong approach? any feedback is welcomed.
...early 4th-gens are notorious for interior squeaks and rattles, you may want to try installing sub-frame connectors to tighten up the car.
sub frame connectors??? I thought that was for excessive body roll. well, i guess that might do teh trick. do you know any good brands? I would like to get a bolt on one if possible
...try searching "subframe connectors" in the LT1 section and there are many descriptions of the usefulness of subframes.
They basically tighten up the body (uni-body), therefore creating less creaks/rattles up through the suspension&chassis.
