Tar remover
Old Nov 3, 2003 | 04:20 PM
RENE95Z's Avatar
Tar remover
I was washing my car and discovered that I found some tar or something that managed to sling down the side of my car. Well, the Z-7 car wash does not remove it, so I have to resort to a tar and bug remover to get the stuff off. Now, will this take off the Zaino that I have on my car or am I pretty much safe?
Old Nov 3, 2003 | 11:52 PM
camaro6's Avatar
I don't use zano or anything, but my best guess is that it will take it off.
Old Nov 4, 2003 | 09:49 AM
KevinSS's Avatar
Not knowing exactly what brand of tar and bug remove you are using I can not say whether it would remove the Zaino, but it really makes no difference as you will want to wash the area you used the solvent on and re polish (Zaino) the surface anyway.
I remove tar with Stoners Tarminator, it does not seem to adversely effect or dull the surface like other solvents. '
You can also use WD-40 to remove tar and wash with car wash and water after its use.
Old Nov 4, 2003 | 11:02 AM
blkZ28Conv's Avatar
Lightbulb
One of the better tar removal agents is "Pure gasoline". You will have to re-apply protectant afterward following claying ( to removed invisible tar specs from paint, and a wash. Gasoline works as a solvent so saturate an old cotton rag and just wipe off. You will be amazed how easily clumps of tarry material just wipes off ( dissolves ). This method is completely non-abrasive.
All your commerial Tar removers use the same ( solvent ) principle. If you have a lawn you have the best tar remover available ( lawn mower gas can).
Old Nov 11, 2003 | 11:21 PM
KillerTA's Avatar
lacquer thinner will work the best
I found that store brand bug and tar removers suck.
Old Nov 12, 2003 | 05:10 AM
blkZ28Conv's Avatar
Be careful with lacquer thinner on single-stage paint and older clearcoated finishes.
Old Nov 12, 2003 | 07:11 AM
Drumhawk's Avatar
I have some tiny tar marks at the bottem of the side-panel and inside the rims. Are you sure the gasoline wont hurt the clear-coat? I drive a 02 hawk and don't want to take any chances. I have all the zaino products and the claybar wont do it.
Old Nov 12, 2003 | 07:17 AM
moparman's Avatar
I wouldn't use lacquer thinner. That stuff will ruin paint. Guess how I know?
I'd try a liberal amount of WD40. Let it work a couple of minutes, then try the clay.
Old Nov 12, 2003 | 07:21 AM
blkZ28Conv's Avatar
If you are only removing tar from painted areas, gasoline will do the job and not create any ill-effects to the finish. It will require you to re-apply a protectant but that's it. For re-assurance stop by a paint/body shop and also confirm this. I also clay after removing the macro tar spots and wash area with a car shampoo.
You will be pleasantly amazed how will this works, how quickly it works and how paint safe ( solvent activity verses using an abrasive) this method is.
Old Nov 12, 2003 | 08:33 AM
Drumhawk's Avatar
Thanks for the advice. I'm looking forward to getting the sticky stuff off my car. I'll try the wd-40 or the gas.
Old Nov 12, 2003 | 08:55 AM
blkZ28Conv's Avatar
Drumhawk,
You're welcome. This would be a great time to do a side by side test of both methods. WD 40 and gasoline. Would you do one and post your results. I have already compared the two. Both work very well, I just found that gasoline worked better. Both methods work by dissolving the tar. Gasoline required less rubbing ( quicker dissolution).
Please post results. This is a problem that all motorist run into once in a while.
Old Nov 15, 2003 | 11:20 AM
birdblack's Avatar
Gasoline goes in your tank, not on the side of my car. Stoner's Tarminator. I see no visual affect to the finish but I follow the Tarminator up with a couple of coats of Zaino.
Old Nov 16, 2003 | 05:41 AM
blkZ28Conv's Avatar
Read the ingredients in Tarminator ( I am sure this is a wonderful product like other products by Stoner). Review your basic HS chemistry and compare these items. Many are derivatives of crude oil ( ie Petroleum distillates).
There is always a market for people to buy commercial items when a similiar product is already at home ( WD40 and gasoline) to do the same job at no cost. Products like Tarminator are great for people who do not own or maintain property ( cut grass, trim trees, bushes, pressure wash stonework, etc). No need to have a can of gasoline laying around. Almost every tool box contains a can of WD40. I guess you can at least brag that you use Tarminator to remove those unfortunate tar spots.
Sign of intelligence, brainwashed by fancy packaging of a product or ignorance about the process and ingredients involved?
Avoided being conned that every process requires a fancy product to get it done.
Not a flame, just a statement of facts.
Old Nov 17, 2003 | 07:00 AM
Drumhawk's Avatar
Thanks again for the advice blkz28conv, the tar is under the door panels right at the bottem of the side-body and more tar right inside the clear-coated rims. I'm going to do it this week and I'll post results with before and after pics too. It's been there most of the summer but i was scared to do anything that might cause swirl marks in the clear. Thank god you can't really see them except up close and I'm gonna be really happy to see them gone.
Old Nov 17, 2003 | 07:03 AM
Drumhawk's Avatar
My only concern is damaging the clear-coated paint or the clear-coated rims. Not worried about removing the zaino cause I'm gonna put 10 coats of zaino on over the winter.
