Special cleaners for convertible tops?
Old Jul 12, 2002 | 01:00 PM
Nevermore
Guest
Posts: n/a
Question Special cleaners for convertible tops?
Any sort of cleaners specifically designed for vert tops that I should use on the top?
Old Jul 12, 2002 | 08:45 PM
KevinSS's Avatar
Post
Your not giving me much to go on as you did not list the type and year model car and you don't have a signature, but:
The top material on F bodies is a canvas material made by this company
www.haartz.com
I use Haartz brand name cleaner and then seal the fabric with 303 Fabric Guard.
A properly maintained cloth top should bead water AT ALL times, if it does not the
cloth sealant applied to it at the www.haartz.com factory has broken down leaving the top material prone to staining and discoloration. The 303 Fabric Guard is
invisible and will reseal the top material.
I have both of these products in stock, the Haartz cleaner is not sold in stores and is
hard to find. Both of these run 27.50 plus shipping. Send me an email if you need the
correct products for the fabric.
Here is the procedure;
Important: A program of keeping the top clean through regular washings BEFORE
it gets dirty, will enhance the life and beauty of an acrylic top and make successive
cleaning easier.
Most automatic car washes will not harm sport topping fabrics. Washes with water
jets and hanging cloths are preferred. Those using heavy barrel brushes should be
avoided. Haartz recommends hand washing in the shade or partial shade, not direct
sunlight.
Bird and tree droppings as well as other loose particle soils should be removed
immediately. Vacuum the top with a brush attachment and rinse the roof fabric
thoroughly with water to remove these loose particle soils. This will also prevent the
soils from being redeposited during the cleaning process. Once the top has been
rinsed thoroughly, spray apply Haartz Roof Cleaner evenly over the entire top while
the top is still wet. Washing with soap and warm water is a safe alternative to
Haartz Roof Cleaner, but not as effective. DO NOT USE DETERGENTS. Allow the
roof cleaner to soak into the top for 10 to 20 minutes and then scrub the top lightly
with a soft nylon brush or terry cloth rag. Rinse thoroughly, preferably until no
remaining soap foam is observed. Allow to dry. Additional cleaning may be
required. It is best to determine this after the top has dried completely. After drying,
cleaning must be followed by re-water repelling the fabric with a fluorocarbon
system such as 303 High Tech Fabric Guard . Failure to do so will result in rapid
resoiling of the unprotected fabric.
The fabric itself does not promote mildew growth. However, mildew may grow on
dirt and other foreign substances that are not removed from the fabric. For these
more stubborn cases, soak the fabric for approximately 20 minutes in a solution of
no more than ½ cup (4 oz.) bleach and ¼ cup (2 oz.) Haartz Roof Cleaner per gallon
of water and scrub lightly as indicated above. Excessive soaking with the bleach
solution can deteriorate seam threads, so be sure to rinse thoroughly.
Rinse entire vehicle to remove all of the bleach solution from fabric and to prevent
streaking on painted and chrome surfaces. Acrylic fabric readily absorbs water but
dries quickly. Several cleanings may be necessary.
Do NOT use top dressing cleaners or conditioners containing silicones, organic
solvents, petroleum distillates or plasticizers that may permanently stain the fabric.
This product is made from 100% solution dyed acrylic fiber which is thermoplastic.
Do NOT subject to excessive heat.
The use of stronger cleansers should be left to professionals experienced in handling
this type of fabric to avoid discoloration and degradation of the special protective
inner layer
96 Black Impala SS
Authorized Zaino Showcar Polish Distributor
www.zainobros.com
Remember #3
Old Jul 13, 2002 | 12:09 AM
Nevermore
Guest
Posts: n/a
Post
sent you mail
Old Jul 13, 2002 | 01:09 PM
KevinSS's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Nevermore:
sent you mail</font>
Did not get the mail?
96 Black Impala SS
www.zainobros.com
Remember #3
Old Jul 13, 2002 | 08:02 PM
Nevermore
Guest
Posts: n/a
Post
<font face="Verdana, Arial" size="2">Originally posted by KevinSS:
</font>
we emailed back & forth last night. That was me
WildRidez
Feb 23, 2015 07:24 PM
ChrisFrez
Feb 15, 2015 07:49 AM
nosliw
Feb 7, 2015 01:30 PM
Collector Car
Jan 5, 2015 10:58 AM
squarehead
Nov 21, 2014 08:02 PM
