powdercoating
Old Jul 9, 2009 | 08:00 PM
green96ta's Avatar
powdercoating
Im getting ready to have just about all my front suspension powdercoated. just wondering if i have my calipers powdercoated will the 400 degree cure oven mess up the calipers?
Old Jul 9, 2009 | 11:00 PM
Mr.GearheadZ28's Avatar
The curing process will not harm the calipers, they get +/- that hot when in hard braking. I recommend getting them powdercoated with a ceramic base paint or use VHT flameproof coating which is good to 2000 degrees farenheight. You ever have any more questions related to paint feel free to ask.
Old Jul 10, 2009 | 03:31 AM
Larsv8's Avatar
Not to hijack but....
I am doing heads and cam soon on my 95 z28 and I am going to the powder coater to spruce up the bay. My question is what can be safely powder coated and what can't? I bought a bunch of spare parts, alt bracket, smog bracket, brake booster resevoir, intake manifold, water pump, etc.
The three that concern me are the throttle body, water pump and brake boost resevoir.
Obviously the brake booster resevoir (i think thats what it is called? the piece mounted on the driver side firewall) has a plastic attachment on the metal piece, so that is out, but can it be detached and just the base painted? The throttle body has moving parts and I don't want to melt anything internal, but to be honest I don't know what pieces and materials are in there. The water pump obviously has bearings and I am assuming some sort of lubricant inside, and I don't want to burn it up.
Thanks for any input!
Old Jul 10, 2009 | 12:55 PM
I wouldn't paint your throttle body unless you disassemble it and only paint the casting. You can powdercoat the water pump, just be sure to mask off the gear and coolant passages. As for the power brake booster, I wouldn't even consider removing it. I would just mask everything around it thoroughly and paint it. If you want to go to the trouble knock yourself out but to do it the right way takes a lot of time and anguish.
Old Jul 13, 2009 | 08:55 PM
green96ta's Avatar
hmm
i cant decide if i want to coat the calipers silver or red. my car is green and i have silver wheels....what do you all think??
Old Jul 13, 2009 | 09:05 PM
cobra12's Avatar
Pics of car?
Old Jul 13, 2009 | 11:09 PM
green96ta's Avatar
pics
as requested. the wheels in the pics are different than the ones i have now. i now have the hp design evo.
Old Jul 14, 2009 | 11:27 AM
cobra12's Avatar
I'd say red.
Old Jul 14, 2009 | 07:26 PM
red X2
Fastbird93
Apr 9, 2016 07:01 PM
Henson071
Sep 18, 2015 04:01 PM
Schismblade
Apr 28, 2003 06:19 PM
poloz28
Feb 3, 2003 06:33 PM
