Polishing
Polishing
Hey I want to remove swirl marks and restore some shine to my paint, so I was wondering which polish I should use. Should I use Meguiars Polish, 3M Polish (39009), Safecut, or Zaino, which if i understand correctly isnt such an abrasive, as a super fine wax almost that fills in swirls, and theoretically seems better. And by the way most likely I will be applying it by hand rather than buffer if that makes a difference.
how bad are the swirls ?? and are you against using a buffer. i would invest in one, the results are not even comparable. i'd use some meguiars # 9 swirl remover. it acts as a polish too. i have had some good results with this stuff
carguyshu
Jan 22, 2017 11:19 AM
Catmaigne
Jul 14, 2015 05:17 PM
This "Appearance" forum is for modifications like hoods, ground effects, paint jobs, stuff like that
