Paint
Old Dec 15, 2013 | 12:46 PM
Chet1185's Avatar
Paint
Would a pint of ready to spray be enough for 1 hood?
Sent from my LG-LS860 using Tapatalk
Old Dec 15, 2013 | 12:52 PM
Chet1185's Avatar
Re: Paint
My bad. If this could be moved to paint/body care
Old Dec 27, 2013 | 12:16 PM
Zfbod94's Avatar
Re: Paint
Normally, yes.
Is the hood in primer or is it already the color you are spraying? Is it a solid color or a metallic color?
With a solid color it will definatly be enough, with a metallic color over primer you will be stretching it close, depending on how you spray. A metallic color will need 2 coats to get desired coverage, along with a mist coat so that the metallics and micas are even and flow nicely.
Old Dec 27, 2013 | 12:26 PM
Chet1185's Avatar
Re: Paint
Medium teal blue metallic
Old Dec 28, 2013 | 09:28 AM
Zfbod94's Avatar
Re: Paint
if that color is already on the hood or something similar and not priming(which you shouldnt have to unless you have any body filler spots), then it should definatly be enough. If your shooting it over white or gray primer, it will be very close to enough, depending on your spraying techniques.
GREEN3112
Feb 10, 2019 09:19 PM
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
92_RS_305
Sep 8, 2015 07:47 PM
