Paging Mike, or Kevin
I have a car cover guys, made by Big Sky car cover with the same fabric california car cover uses.
It is listed as "Dust top" I think, seems pretty soft, but what i was wondering, if when i'm putting it on and it rests/slightly rubs against the paint.......will it swirl?
Yup, I concur with Kevin.
Otherwise, regardless of the material, if you rub in or bump against dust or dirt, it is likely to swirl or scratch. Even with the softest & safest material on Earth, rubbing it againt dusty paint (without some kind of lube, but that's obviously impractical here) is a sure way to swirl. Make sure the car is clean, dust free, and you're fine, unless the material itself can cause swirls.
Oh I definitely believe that your car is ultra-clean! Shouldn't be a problem for you.
About the material though, never used it, so can't really say there... but if it's a good quality like CCC it should work out just fine.
cmsmith
Aug 27, 2015 06:37 PM
cmsmith
Aug 20, 2015 07:57 PM
