How to tell if car is clear coated?
Old Dec 12, 2004 | 11:20 AM
MRBoss429x's Avatar
I was thinking about ordering some zaino but don't know whether to get z-2 for clear coated, or 2-3 for regular paint. Is there a way to tell if my car is clearcoated or not. The problem is that it was repainetd after a factory defect so the paint is not original. Also the rear and front bumpers have been repainted and Im not sure of the paintshop sprayed any clear. There are pictures in my sig and in person you can notice some orange peel if any of that helps. Thanks.
Old Dec 12, 2004 | 11:27 AM
97BBlackZ's Avatar
Re: How to tell if car is clear coated?
My Guess is that it has a clear coat, i don't see why they wouldn't put a clear coat on. I think the only cars that don't have a clear coat now adays are the real old ones. If i remember correctly i think the difference is that the clear coat makes it shine since its like a glaze kind of.
Either way if your car didn't have a clear coat where they resprayed it then i think you would have to end up getting both. 1 for the clearcoated section and one for the non clear coat section.
Old Dec 12, 2004 | 03:43 PM
Jeffw's Avatar
most likely it is clear, only macco and shieb does single stage jobs. you can look close if you have any scratches that will hlep you tell. if it is single it should look like color in it, clear you can almost see sideways into it.
jeff
Old Dec 12, 2004 | 10:21 PM
KevinSS's Avatar
Just order the Z-2, there is a 99% chance that your car has clear everywhere, even if it does not you can use Z-2 on non clear and clear and you can use Z-3 on clear and non clear. Z-2 and Z-3 are the same except that Z-3 contains an extra additive to hinder oxidation that is prone to happen on older single stage paints.....
Old Dec 13, 2004 | 09:43 PM
MRBoss429x's Avatar
Thanks a lot!
Old Dec 13, 2004 | 10:04 PM
Brangeta's Avatar
Well, a car with clearcoat usually looks wet or you can see yourself in the paint pretty well. That's just my 2 cents... or half-sense...
Old Dec 14, 2004 | 12:43 PM
JohnD's Avatar
Get some wet or dry sandpaper and wet sand a spot somewhere that it doesn't show. If no clear coat, the color will show in the part you sand off, if clear coat, it will be whitish.
Old Dec 15, 2004 | 04:04 PM
KevinSS's Avatar
Easier than that, take some rubbing compound in a small spot and rub it on the paint, if the applicator turns the color of the car, it is NOT clear coated...
LT14LIFE
Feb 9, 2015 09:35 PM
blac94Z
Nov 28, 2014 01:53 PM
USAirman93
Nov 24, 2014 03:37 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
