Full Detail Using Zaino
Old Apr 21, 2006 | 11:03 PM
aaron1987's Avatar
My zaino arrived today (ZFX, Z2, Z5, Z6, Z7) and I'm getting ready to spend the time to do a proper detail to the Z. There are light swirl marks and fine scratches almost everywhere but for the most part the paint looks great for being 12 years old. I do not own an orbital buffer so all the work will be done by hand.
My question primarily concerns removal of the swirl marks and scratches; what polish/abrasive will effectively remove them by hand without diminishing the effect of the zaino? Also, should I wash the car after polishing or leave it under the Zaino application?
Old Apr 22, 2006 | 09:39 AM
95LT1conv's Avatar
Re: Full Detail Using Zaino
my advice would be to get a porter cable 7424. it will take of the swirls and light scratches quickly and effectively. you can get them as a kit with pads relatively cheap on ebay. it will take you forever to get swirls and scratches out by hand if at all.
Old Apr 22, 2006 | 11:36 AM
aaron1987's Avatar
A PC is on the to do list but for now I don't have one so I was looking for input on what I can do to help (even if the end result isn't *perfect*) for now.
Old Apr 23, 2006 | 02:35 PM
95LT1conv's Avatar
i hear the zaino zpc will get the job done by hand
Old Apr 24, 2006 | 07:59 AM
hcvone's Avatar
It will work by hand, but it will be an all day job by hand.
Old Apr 24, 2006 | 08:20 AM
Threxx's Avatar
I hear of people getting disasterous results trying to use it with a porter cable or similar... what's the trick to that?
Old Apr 24, 2006 | 10:44 AM
JoeliusZ28's Avatar
i use a standard orbital buffer as well as hand application, and it yields excellent results. i dont understand why they say you arent supposed to use machine, it works very well with a machine from my experience.
Old Apr 24, 2006 | 01:13 PM
95LT1conv's Avatar
if you read the instructions on zainostore.com, it says you need to use the proper pad @ a speed setting of 4.5. iwould assume it means a light cutting/polishing pad. a hard cutting pad is probably what caused the poor results since the zpc is rather abrasive.
Old Apr 24, 2006 | 03:37 PM
95LT1conv's Avatar
i just got an email back Sal and he said to use the lighest cuting pad to apply with. if the zpc starts to duct you went too long. he says 1 line of zpc across the pad and work it for a few minutes on speed 5 or 6 on the pc.
Sergio
Jan 27, 2016 04:27 PM
meissen
Jun 1, 2015 07:59 AM
Apr 16, 2015 09:57 AM
ChrisFrez
Mar 29, 2015 09:43 PM
NewsBot
Mar 19, 2015 12:20 PM
