convertible top maintenance
Old Dec 30, 2005 | 12:10 AM
98Zragtop's Avatar
Has anyone used any products available for convertible tops to help them repel water? I have read about a few but am concerned about trying something that could damage the top material. My car has always been garaged, but since the top is original, I was thinking that such an application would benefit it. It would be helpful to hear from anyone who has tried such products. Thanks for any information anyone can give me.
Old Dec 30, 2005 | 12:45 AM
Honda Hunter's Avatar
Re: convertible top maintenance
I wish there was more info on 4th gen camaro verts. Like pump information wiring and top care etc.
Old Dec 30, 2005 | 08:54 AM
LaSSt One's Avatar
Here is the information from Haartz, the manufacturer of our tops...
Although the fabric does not promote mildew growth by itself, mildew may develop on dirt and other foreign substances that are not removed. This is especially true in warm, humid, dark environments. A program of keeping the fabric clean through regular washings, BEFORE it gets dirty, will enhance the life and beauty of the acrylic and make successive cleaning easier.
Most automatic car washes will not harm cloth top fabrics. Washes with water jets and hanging cloths provide a more gentle cleaning action. Those using heavy barrel brushes could damage the top material. Haartz recommends hand washing.
The Haartz Corporation recommends using RAGGTOPP™ Cleaner and RAGGTOPP™ Protectant (available from Wolfsteins Pro-Series at tel: 800-377-4700, fax: 770-395-1353, e-mail: info@wolfsteins.com).
Hand washing in shade or partial shade, not direct sunlight, is best. DO NOT USE DETERGENT. Bird and tree droppings, as well as other loose particle soils, should be removed immediately. Vacuum with a brush attachment and rinse thoroughly with water to remove loose particle soils. This will also prevent the soils from being redeposited during the cleaning process. Once the fabric has been rinsed thoroughly, spray RAGGTOPP™ Cleaner evenly over the entire surface while still wet. Allow the cleaner to soak for 10 to 20 minutes and then scrub lightly with a soft nylon brush or terry cloth rag. Rinse thoroughly, preferably until no remaining soap foam is observed. Additional cleanings may be required. It is best to determine the need for additional cleanings after the fabric has dried completely.
Washing with soap (ie. Ivory or Lux) and warm water is a safe alternative to RAGGTOPP™ Cleaner, but not as effective.
For more stubborn cases, mix a solution of no more than 1/2 cup (4oz.) bleach and 1/4 cup (2oz.) RAGGTOPP™ Cleaner per gallon of water, soak for approximately 20 minutes and scrub lightly as indicated above. (Excessive soaking with the bleach solution can deteriorate seam threads.) Rinse thoroughly to prevent streaking on painted and chrome surfaces. Several cleanings may be necessary.
Once dry, cleaning must be followed by re-water repelling with RAGGTOPP™ Protectant. (This product does not contain CFC's and therefore, is not harmful to the environment.) Failure to apply will result in rapid resoiling of the unprotected fabric.
Old Dec 30, 2005 | 11:07 PM
98Zragtop's Avatar
Thanks for the information about Haartz. Seems like this would be a good way to maintain the fabric.
Old Jan 1, 2006 | 12:49 AM
LaSSt One's Avatar
Yep, Raggtop makes some good stuff. Water will bead off like you have Zaino'd it. Not sure if any sponsors sell it, but afterthoughtsauto.com carries it.
timmy39120
May 2, 2015 05:12 PM
WildRidez
Feb 23, 2015 07:24 PM
nosliw
Feb 7, 2015 01:30 PM
joe777107
Dec 1, 2014 09:32 AM
squarehead
Nov 21, 2014 08:02 PM
