Cleaning an LT1 Engine.
Okay my engine is getting dirty and I want to pressure wash it. One problem. Opti-Spark dosen't like water.
Can I pressure wash it while it's running? What do you guys do cause I'm stumped.
Re: Cleaning an LT1 Engine.
If you are careful, there shouldn't be any problems.
- let engine get slightly warm and shut off
- cover PCM, alternator, and fuse box with aluminum foil
- spray compartment lightly with water
- apply diluted degreaser and let dwell for a couple of minutes
- scrub everything with a variety of brushes and mitts using soapy water
- rinse compartment lightly with water
- remove foil and run engine for about 5 minutes
- apply dressing/protectant after everything dries
If you are super worried about the opti, put a plastic bag or foil over it.
Avoid drenching any area of the engine compartment and you'll be fine.
Originally Posted by moparman
I would not pressure wash the engine. In addition to the opti, there are various sensors and connectors that could take a hit from a high pressure spray.
Either method you choose, you just have to use caution and common sense. Never put the water source close to any electrical part.
when I had my LT1 I just lightly misted the engine with a nozzle sprayer, then wiped it clean. Windex works well on tough grease. After which I used armor all to make things shiny.
oldschool
Feb 9, 2016 09:21 PM
