best way to remove tape residue?
Old Apr 6, 2010 | 11:53 AM
dragginS10's Avatar
I previously had ground effects on my car that I just took off but the double sided tape residue is still there. Is there a good way to remove this with out damaging the paint? I tried goo gone but it didnt work to well
Old Apr 6, 2010 | 12:47 PM
Mr.GearheadZ28's Avatar
WD-40 or naptha should remove the tape residue.
Old Apr 6, 2010 | 03:13 PM
94CamaroZ28/SSClone's Avatar
Goo Gone, Kragens has the bottle.
Old Apr 7, 2010 | 12:36 PM
R_ADKINS80's Avatar
3M adhesive remover is the best stuff I've ever used for that.
Old Jun 8, 2010 | 09:51 PM
TheV6Bird's Avatar
Have you tried putting a blow dryer or heat gun to the residue? Could soften it up a bit for you to peel back.
Old Jun 16, 2010 | 04:08 PM
TD95Z's Avatar
If it hasn't dried out so much that it's crumbling, try heating it and then rolling it with your thumb. Ideally, it will roll into nice little nuggets and leave behind little residue. The more you can get off WITHOUT using Goo Gone, laquer thinner, etc. the better. However, if it is dry and crusty, skip straight to the laquer thinner. It wont harm a cured basecoat/clearcoat finish, but test it first.
Old Jun 26, 2010 | 10:58 AM
Meshuggah6's Avatar
PPG DX330 wax and grease remover.
Old Jul 6, 2010 | 05:40 PM
averagejoe55's Avatar
walmart sells the 3m adhesive remover. awesome stuff
IndyZman
Oct 22, 2015 02:17 PM
greenzee28
Sep 25, 2015 04:29 PM
wbspoon
Sep 19, 2015 08:12 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
