beading water..im confused..
Old Apr 11, 2004 | 10:52 AM
sabre81's Avatar
i dont understand the water beading concept. Doesnt water naturally bead? i mean it doesnt absorb. someone enlighten me
Old Apr 11, 2004 | 12:30 PM
KevinSS's Avatar
Water only beads on surfaces that have surface tension.....
Old Apr 11, 2004 | 03:28 PM
sabre81's Avatar
doesnt any flat metallic painted surface have surface tension? im not bashing wax or anything by the way, im the 1st one to throw 10 coats of wax on my car, im just bored.
Old Apr 11, 2004 | 03:35 PM
KevinSS's Avatar
Flat metallic painted surface?? all cars have been clear coated since the late 80's, water or wax never touches anything to do with the color coat of the car, it is sealed with a clear layer of paint hence the clear coat. Every surface has some degree of surface tension, wax magnifies this surface tension making smaller and smaller beads of water..
Old Apr 11, 2004 | 11:10 PM
Error's Avatar
10 coats of wax? Why? Most waxes strip off the coat beneath it, thus applying one coat.
Old Apr 12, 2004 | 07:08 AM
sabre81's Avatar
im exaggerating slightyly. but i have stick on 4-5 coats before. Are you sure it rubs it off. I read somewhere that if you let the car sit for like 12 hours you can "stack" coats. i added these 5 coats over winter with a day in between each.
Old Apr 12, 2004 | 10:16 AM
KevinSS's Avatar
It depends on what type of wax you are using, if it is a cleaner wax then it strips the previous coat.............
Old Apr 12, 2004 | 11:02 AM
sabre81's Avatar
interesting, i didnt know that. this was probably a wasted effort but, i used 2 coats of eagle on polish&wax then 2 coats of rain x wax, and one coat of turtle wax.
Old Apr 12, 2004 | 04:41 PM
KevinSS's Avatar
Wow, you used a lot of products,,,, basically you now have one coat of Turtle on there, all of those are cleaner waxes....
Old Apr 12, 2004 | 10:02 PM
sabre81's Avatar
well crap
PoloGreen 3.4
May 19, 2004 07:49 PM
94REDSTALLIONZ
May 15, 2003 11:28 AM
Allen66
Nov 15, 2002 11:00 AM
MikeLS
May 17, 2002 06:41 PM
