Apply Zaino with porter cable orbital buffer?
I have been using Zaino on my red '95 Z28 for about 5 or so years now and love the results
. I am going to be picking up a porter cable random orbital buffer (either the 7336 or 7424) and was wondering if results would be better or worse with the buffer? Can I use the buffer to apply Z-2 and Z-5? Which pads should I use for each of those products? Any advice on any "proper" technique for Zaino use with a buffer would be great!
Jeff
. I am going to be picking up a porter cable random orbital buffer (either the 7336 or 7424) and was wondering if results would be better or worse with the buffer? Can I use the buffer to apply Z-2 and Z-5? Which pads should I use for each of those products? Any advice on any "proper" technique for Zaino use with a buffer would be great!Jeff
Re: Apply Zaino with porter cable orbital buffer?
You can use the PC to apply Zaino, but it's really a personal preference thing. Not necessarily an advantage or disadvantage.
If you decide to apply via PC, you would want to use a grey finishing pad.
This article may help some: http://autopia-carcare.com/zaino.html
Hey Jeff,
I recommend you check out Zaino's website (www.zainobros.com) for tips on applying Zaino.
I'm not sure about using an orbital buffer to apply Zaino???
Just checked the site
I guess you could use the buffer to apply, but removal suggests "up/down" on vertical surfaces, "front/back" on flat surfaces.
I've always Zainoed by hand.
I guess you could use the buffer to apply, but removal suggests "up/down" on vertical surfaces, "front/back" on flat surfaces.I've always Zainoed by hand.
You can use the black or gray soft finish pad to apply either z-2 or Z-5 but its really much easier by hand you will use about 1.5 more product with the buffer pads....
tommalcolm
Sep 11, 2015 03:39 PM
