93-97 headlight trim fading
looking at various pics of other lt1 camaros, most guy's headlight trim is dark with no blemishes at all. Mine is all faded and more grey than black. I used to use a product called Stoner's Trim Shine, and that would make it good for a few days, but not permanent. Now, living in VA, I can't find it. Any suggestions to restore it's brilliance?
Re: 93-97 headlight trim fading
I tried something that worked on my 93 camaro today--just simple Armorall did the trick, and the black is back to its origional brilliance.
I also used it on the wiperblades and that worked really well. I dunno how it will hold in the rain, but then again I don't drive when it is wet out...
Anywho, Armorall worked for me =)
goodluck
goodluck
Originally Posted by EHuff
I do not know if Back to Black would work or not. The next time I had the time I would stop by the store and read the label to see if it might work for you.
Does "Back to Black" also work for the black strip between the T-tops?
just tried to paint my uro parts headlight trim and i think it looks good! Looks similiar to the Audi TT lamps. I added 'citylights' to the high beam area, looks great...
___________________
93 Formula Mods: 383, LE2 Heads/Intake, 226/230 cam, 52MM TB, Magnaflow cat back, LT headers, uro parts, CAI, SFC, Strut Brace, Adj LCA, Adj Panhard, Relocated Torque Arm, Progressive Rate Springs, Short Throw Shifter
___________________
[QUOTE=lackneramanda;6712255]just tried to paint my uro parts headlight trim and i think it looks good! Looks similiar to the Audi TT lamps. I added 'citylights' to the high beam area, looks great...
[QUOTE]
Pics...
[QUOTE]
Pics...
Just wax it with some Meguiars gold class wax and see what happens. That's all I use on the '95 and it looks pretty decent. Back in 2002 I had a professional polish the car and use an acrylic sealant on all the paint, and that oddly enough turned what used to be matte black into semi-gloss black.
They polish up nicely with normal rubbing compound and glaze. Go easy, though, as the finish is not clearcoated and there isn't alot of color to work with. I had the whole thing cleared when the nose was repainted, and while not 100% stock-looking, it was hassle free and looked great.
jackpawt883
Sep 10, 2015 08:53 PM
