I'm looking to convert to a TH400, RMVB, Transbrake. Here's what I'm looking to swap:
https://www.camaroz28.com/forums/sho...d.php?t=774328
Probuilt T56
Spec Stage 3+ clutch & steel flywheel
Pedals
Hydraulics
Hurst shifter
Hurst ****
Spohn Top Gun Driveshaft
Probuilt T56
Pedals
Hydraulics
Hurst shifter
Hurst ****
wat all do you need because i can get my hands on transmission if you like
can u send me a pic of what you have to trade
I would need a TH400 (short tail), preferrably built to handle 600+ TRQ. Ideally, it would be a RMVB with a trans brake. I also need a flexplate, flywheel and cross member. Also, if someone had a good torque converter, shifter and a longer steel drive shaft for a TH400 trans I'd take that too.
As for having pictures, everything's still in my car. If I found someone local, they could actually come by and try out the tranny/clutch before buying it.
Eric
Eric
well i believe that i can get most of the things that you look for but the transbrake is a little hard
Ive got a Hurst RMVB quarter stick shifter that I would take $100 for ... Its this one, http://www.summitracing.com/parts/HUU-3160001/
