Need metal fuel lines, throttle cable, and gas pedal
Old Jan 31, 2008 | 09:06 PM
snod83's Avatar
I need the metal fuel lines from the rear to the front of the car on a 94 z28. Also, I need a throttle cable and gas pedal for the same car. Its a manual trans, if that matters.
Let me know what you have,
Ryan
snod83@gmail.com
Old Feb 1, 2008 | 04:00 PM
ninety4three4's Avatar
sent you an email
Old Feb 1, 2008 | 04:54 PM
guest74777's Avatar
Guest
is it a traction control car?
Old Feb 1, 2008 | 06:43 PM
jarretthise's Avatar
i have fuel lines for you....and the pedal is a complete assembly with the brake, i also have it...just PM me plz if you want anything
Old Feb 1, 2008 | 07:33 PM
snod83's Avatar
It's a non traction control car. Also, I just need the gas pedal rod, I don't need the entire assembly. I am also not sure if it is the same pedal as an automatic, so I would like one from a manual.
Thanks,
Ryan
Old Feb 1, 2008 | 10:49 PM
ok yea ill check and see as i am doing a 6 spd swap right now....i will check the two pedals and compare the difference..i also have the fuel lines, are you interested??
Old Feb 4, 2008 | 02:36 PM
91LT16SpdFormy's Avatar
Ive got a brand new GM throttle cable if you need it?
edman
Jan 25, 2015 02:41 PM
Jul 4, 2005 05:00 PM
Aneurysm
12
Sep 10, 2002 05:21 PM
simple
Aug 11, 2002 11:56 AM
