Emergency brake cables mounting bracket
Old Nov 8, 2012 | 11:29 AM
dchatcher's Avatar
I am looking for the Emergency Brake Cables Mounting Bracket that bolts to the underside of the body and the 2 brake cables from rear attaches to it.
Also the piece that the 2 cables attach to and the cable from the brake lever also attaches to at the Bracket assembly.
I have a 2002 Camaro rear end that I am putting in a rod. I think this same bracket and piece was used on a number of Camaro year model as well as other GM makes.
Old Nov 8, 2012 | 05:56 PM
ddr698's Avatar
Re: Emergency brake cables mounting bracket
I have the cables you need and also the brackets that were on the rearend. Also have have the brake lever/cable. I think the mounting point you are looking for on the underside of the body is spottwelded tho. i could cut it off if you wanted but im not sure if itd do you any good....
SpeedJunkee
Apr 23, 2015 09:51 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
Cam's maro
Jan 8, 2015 05:01 AM
bman555
Aug 11, 2002 10:56 PM
