abs delete kit
you can just use a 3rd gen brake distribution block and presto no more abs plus it will cost like 20bucks depending how much you spend on the block I did it so have a few people over on tech and it works great and you can put it anywhere you need to PM me if you want some details
Non ABS
I did my set up using Wilwood Master Cly (No Vac Booster) , Wilwood billet firewall adpt. An adj. rear bias valve for the rear.
The total spent was about 15 bucks in steel lines, fittings, and about 175.00 for the Master cly, firewall adapt., rear bias valve.
Now I have tons of room on the drivers side firewall, and strut tower...
carguyshu
Jan 22, 2017 11:19 AM
armedtrigger
Feb 24, 2015 08:30 PM
squarehead
Jan 15, 2015 07:02 PM
