98-02 front end conversion
Old May 16, 2005 | 09:02 AM
biggmikolow's Avatar
i want to do the swap..what will i need?? and how much will it cost
Old May 16, 2005 | 09:12 AM
jst's Avatar
jst
Re: 98-02 front end conversion
Do you have to replace the fenders or can the 93-97 be modified?
Old May 17, 2005 | 07:13 PM
jst's Avatar
jst
Anyone do this?Are the lights plug ins or wire splicing?
Old May 18, 2005 | 07:02 AM
KHelfrich's Avatar
I did the swap and you need both fenders front bumper cover and foam backing also headlights and bracket and you also need this like fiberglass piece that goes between the headlights you also need to either extend the corner posts that the hood sits on or weld in the higher brackets when I did the swap I was also swapping motors and wiring so I cant say weather the plugs will line up
also i have a front bumpercover and drivers fended that had some light damage but have been fixed if anyone needs them there from a 99 frebird
ken
Old May 22, 2005 | 06:12 PM
Carver1's Avatar
I have a front bumper cover off of a 00 camaro. It is red with a 2 inch crack near the turn signal. The redt is in great shape. It could easily be patched. Shipping is a bear, but I will let it go cheap.
8T8IROC
Mar 26, 2015 09:02 PM
karguy16
Mar 6, 2015 01:33 AM
grabbem88
Feb 23, 2015 09:41 PM
siguy
Nov 27, 2014 10:07 AM
