98-02 front end conversion
Subscribe
May 16, 2005 | 09:02 AM
i want to do the swap..what will i need?? and how much will it cost
Reply
May 16, 2005 | 09:12 AM
Re: 98-02 front end conversion
Do you have to replace the fenders or can the 93-97 be modified?
Reply
May 17, 2005 | 07:13 PM
Anyone do this?Are the lights plug ins or wire splicing?
Reply
May 18, 2005 | 07:02 AM
I did the swap and you need both fenders front bumper cover and foam backing also headlights and bracket and you also need this like fiberglass piece that goes between the headlights you also need to either extend the corner posts that the hood sits on or weld in the higher brackets when I did the swap I was also swapping motors and wiring so I cant say weather the plugs will line up
also i have a front bumpercover and drivers fended that had some light damage but have been fixed if anyone needs them there from a 99 frebird
ken
Reply
May 22, 2005 | 06:12 PM
I have a front bumper cover off of a 00 camaro. It is red with a 2 inch crack near the turn signal. The redt is in great shape. It could easily be patched. Shipping is a bear, but I will let it go cheap.
Reply
Subscribe
