96 Dodge Ram Lift Kit?
Re: 96 Dodge Ram Lift Kit?
Originally Posted by LagunaS3
I'm probably looking for this in the wrong place, but I'm looking for a suspension lift for my 96 4x4 Ram. If you have one, let me know!
I'm wanting to clear 37's...After some research it looks like I'll either have to use FabTech's 5.5" kit with 2" coil spring spacers or a Skyjacker 7" long arm kit. The Skyjacker is probably the way to go...but it's almost $3000.
6.5" $1895:http://www.truckn-store.com/product....t.asp&ID=91816
5" $989: http://www.jcwhitney.com/autoparts/I...26232510387027
5" $709: http://www.jcwhitney.com/autoparts/I...19997810354884
Those are just a few from a quick search I did. I wouldn't spend $3000 on a lift kit thats for sure tho. I also noticed that every manufacturer recomends a smaller tire than what will actually clear. My Lifted 94 Dakota only recomended a 31" tire and 33's cleared. Dodges have big fenderwells, and clear a much larger tire than they say. For instance, I put just the leveling spacers in the front, then i went with the 35" tires...they cleared , but rubbed occasionally on the low speed sharp corners....i put the body lift in and have lots of room...So I believe a 37/13.5's should fit with a 4.5/5" lift. My Rims also stick out a bit further than some, and my summer tread is 35/14.50 MT's....and they dont rub either, just something to think about.
Drtryder
Apr 22, 2015 04:17 PM
NewsBot
Jan 29, 2015 07:10 PM
