Crane 10308 Valve Spring Kit And March Power & Amp Pulley Kit Forsale
The crane valve spring kit is a part# 10308-1. They have under 1000 miles on them. You get the springs, retainers, and locks. You will have to get shims though. These are the springs most of the guys around here run. Their good to .600 lift. They sell for $179.99 at Thunder Racing. I'm looking for $85.00 for the valve spring kit.
I also have the March power amp pulley set with the belt. part# 4485 sells for $106.99+$27.99 for the belt. I would like to get $85.00.
yes you can use them on solid rollers or hyd. rollers. call crane and they will tell you the spring heights to use for your application. if you check under the crane website and look under their street solid rollers the same spring is recommended. all they want you to do is change your installed height. but the max lift is still .600. call crane if it will make you more comfortable. if i could find my instruction sheet it tells you what to install them at depending if it is solid or hyd. let me know i have been getting some bites.
oldschool
Feb 9, 2016 09:21 PM
Jul 4, 2005 05:00 PM
